Heard a Ticking Noise on startup??
Old Mar 8, 2004 | 06:04 PM
99PTA's Avatar
Default Heard a Ticking Noise on startup??
it just started..... my dad said its prolly a lifter....... he wanted me to ask this board if LS1s have self adjusting lifters and if not what does it cost to get it fixed....if thats even the problem.
Old Mar 8, 2004 | 06:12 PM
black_knight's Avatar
The LS1 has a hydrolic lifter system stock, so it should be self-adjusting.
Old Mar 8, 2004 | 06:13 PM
davered00ss's Avatar
Moderator
Check to make sure your plug wires are on good this will cause a ticking sound. Also listen under the car and with the hood up and try to locate it,it may be an tensioner pully.
Old Mar 8, 2004 | 07:32 PM
StevieZ's Avatar
If it is a lifter, you might try loosening the rockers for that cylinder and leaving them loose for about 15 mins. Then retorquing them. Doing this will sometimes cure a sticking or collapsed lifter.
Old Mar 8, 2004 | 08:00 PM
99PTA's Avatar
where could i get this done.???? and estimate cost?
