Something different
So far I am looking at a 5.3 aluminum block, 4.8 crank and rods plus stock flat top pistons. Intake will likely be LS6, exhaust manifolds will be sheet metal Vette stuff as I need the clearance and these are easy to modify. What is a good head to use on this little engine? I am thinking an LS6 cam (or something like the 'old man cam') might be nice on this setup.
Looking for something that will be happy to shift at 6500 or so when I want to have fun and be quiet and reliable.
Car is a hair under 3000 pounds and has 3.91 gears and 25" tall tires, driven at least 10K a year and probably more.
I forgot to mention that I like to build engines and have not done one in a while and would enjoy doing one - especially an engine I have not done before.
Keep an eye on the rev limiter cause they rev pretty fast and 1st gear tends to go past the limiter if you have traction problems. Toasted one over 8000rpm one time, took out 6 rod bearings
