Which heads for a Torquer V3. Cam?
Old Oct 6, 2011 | 06:44 PM
arioch's Avatar
Default Which heads for a Torquer V3. Cam?
ok guys just looking for the absolute best heads to match a Torquer V3 cam i already have in the car, i DO NOT want to swap to a different cam so i need the best heads to match to this cam.
231/234 .643/598 111LSA is the specs
car's other mods
NW92 Throttle Body
92 FAST intake (ported)
MTI Lid
Ported LS6 oil pump
All supporting cam mods
ARH 1 7/8's LT's
TSP True Duels
The car made 419rwhp as is, id like to beat 460 as my buddy has 450....
Old Oct 6, 2011 | 07:48 PM
Darkman's Avatar
Trick Flow 215s
Old Oct 6, 2011 | 10:13 PM
A.R. Shale Targa's Avatar
Originally Posted by Darkman
Trick Flow 215s
THIS^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
from TEA with powdered metal valveguides (stock rocker compatible)
and turned down LS3 valves if pocketbook allows.
Old Oct 6, 2011 | 10:15 PM
arioch's Avatar
i wouldnt pull more power from getting heads with more cc's like their 235?
sorry JUST starting research into heads
Old Oct 6, 2011 | 10:23 PM
southpaw0314's Avatar
AI heads
Old Oct 6, 2011 | 10:48 PM
Larger runners can make more peak power numbers but if you're still stock
cubes...then the 215 will make more average power throughout the power
band by virtue of better port velocity....Chris 1313 runs ten-ohs with this
head on stock lower
Old Oct 7, 2011 | 12:02 AM
arioch's Avatar
head on stock lower
alright i think i understand it now, thx guys 215's it is.
Old Oct 7, 2011 | 01:52 AM
01ssreda4's Avatar
TFS or AFR hands down. Can't go wrong with an aftermarket casting.
Old Oct 7, 2011 | 01:53 AM
dtsti's Avatar
My prc stg2.5 heads made 469whp with that cam.
Old Oct 7, 2011 | 11:09 AM
BrntWS6's Avatar
PRC 2.5 heads are great for the money...I have them with the V3 cam and gained
90 rwhp on a slipping clutch. But he's looking for premium heads. Cant go wrong with Trickflow or anything from TSP
Old Oct 7, 2011 | 11:13 AM
BrntWS6's Avatar
Also...I think you will easily gain 50rwhp or more with good heads on that setup. Good choice of parts, that thing will scream after a solid tune.
Old Oct 7, 2011 | 05:36 PM
garygnu's Avatar
whats your budget ?
Old Oct 9, 2012 | 12:22 PM
BLWN1's Avatar
what did you go with?
