Misfire after engine re-install, need advice
When we first fired her up again, it was on open headers. Thanks to my lack of experience/knowledge whatever you want to call it, left the O2 sensors in while it was running on open headers for maybe 10 minutes. It burnt them up leading to a SES light. Had a misfire at idle (seemed to be only or more so when it was warmed up or under load). Got it checked, sure enough it was both O2 sensors with a misfire code. Then the SES light disappeared the next day (we installed the y pipe the next day). So I replaced the O2 sensors and checked the spark plugs. All the plugs looked nearly brand new (replaced maybe 6 months ago), no buildup or anything on them.
Now while it seems to be running smoother and from what I can tell it is misfiring less than it was before, it still does it while idling at operating temp (makes a "putt" sounding noise every once in a while) and when I give it heavy throttle (about 75%, haven't gone WOT yet) you can feel it stumble/choke up a bit. What could be the cause of this and what do I check next?
Mark
W
