???s with head gasket and milling
Old Oct 11, 2011 | 06:23 PM
doublea87's Avatar
Question ???s with head gasket and milling
ok guys im getting myself confused here and would love some help or guidance.
ive got a set of 806 heads stock cc when purchased (already ported and polished runners) i had a valve job done along with milling to 11:1 compression.
so my problem lies in my math to find what my CR will be with stock head gaskets and im also trying to find a starting point at which to find correct pushrod length by figuring out how much was taken off the heads
so for every .006" milled that = 1cc lowered
stock 69cc chambers taken to 62 cc for 11:1 = .042 was shaved off
stock gasket thickness is .052 or .056 compressed?
either way im looking at just under 11:1 unless more was taken off the heads or i use a .040 gasket. and my starting pushrod length would be around 7.350.
something just does not seem right about this lol
Old Oct 11, 2011 | 08:25 PM
SOMbitch's Avatar
Look at this>>>> https://ls1tech.com/forums/ls1-domes.../t-111207.html
Old Oct 11, 2011 | 08:41 PM
doublea87's Avatar
thanks SOMbitch.
i was actually looking at that graph and to me im getting that every 5.6cc = 1CR and every .006" milled = 1cc so then would milling .0336 = 1CR? this is where im getting confused lol. im not really after just answers, im after HOW to find the answers
Old Oct 13, 2011 | 10:43 PM
doublea87's Avatar
can anyone else help me out here?
Old Oct 13, 2011 | 11:08 PM
01ssreda4's Avatar
Yeah, you need to measure for pushrod length.
Old Oct 16, 2011 | 08:34 PM
doublea87's Avatar
ive got a pushrod length checker on order from comp cams and i just picked up some molding clay this afternoon. im looking to see if the math is right or if im off by a few thousandths
