Callies Compstar Crank?
Old Dec 14, 2011 | 12:25 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Originally Posted by Gray86hatch
I have no idea. They like to spend your $$
Texas speed uses acl in their crate 418 with callies cranks. I have a eagle in mine.
We use a variety of bearings including Clevite, King, and ACL, depending on which bearing we need to get the clearance setup properly.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Dec 14, 2011 | 08:45 PM
driver56's Avatar
Turning a crankshaft is no big deal as long as run-out and taper are held to spec. I have a first-gen SBC that has a factory steel crank turned from a medium journal main (350) to fit in an early small main (327) block. That's 150 thousandths, quite a bit more than taking one just .010 under to clean it up. The rod journals were also off-set ground to 3.562 stroke and reduced from 2.100 to a small journal 2.000. This motor has seen 8200rpm and has been raced hard with no problems. One benefit of turning one this much is it lets you put a nice big radius in the corners to help improve over-all strength. I'm using King Pro-series rod bearings and ACL H-type main bearings, that's what we had on hand at the time.
