#7 bent spark plug electrode?????
Old Oct 13, 2011 | 03:46 PM
silverLSWON's Avatar
Default #7 bent spark plug electrode?????
i was driving my car the other and when i pulled into a parking, my car started popping really bad...when i started looking into it i found that the number 7 cyl spark plug had a bent electrode with ONE tiny little nick on it. the nick is the size of the lead in a mechanical pencil. i put new plugs in, pulled the valve covers to check for bent valves, broken valve spring etc...all that seems normal and functions properly. i then started put everything back together and started it. at first everything seemed normal but once it warmed up a little bit, it had a very faint knocking noise...and some blow by from the oil cap/fill...other than that the motor is smooth and is normal...did i break a ringland on a piston or spin a bearing...Ive heard bad rod bearings before and they were way louder..the knocking noise from cold started ls1's were louder than this...just looking for someone who's had similar issues...i know i have to pull the head off and prob rebuild the bottom end...my oil pressure is great...mods are in my sig
Old Oct 13, 2011 | 07:54 PM
NHRAFORMULA00's Avatar
Sounds like the top of a pistion broke off .
Old Oct 13, 2011 | 10:03 PM
z28241's Avatar
Hey bro sorry to hear that ..get an engine stethascope an point it around points of the motor concerned while its running..
