Should I switch to synthetic....
In another 5-10 years people will start to realize this. I'm just blown away how many people still fall for this marketing scam.
Personally, I have 164,000 miles on my FULLY BUILT stroker engine, and its running like a charm still. 20w50 cheap Castrol GTX non-synth.
Synthetic oil is a better lubricant, lasts longer and has a higher breakdown temperature. Ever wonder why you can't seat piston rings with synthetic oil?
I'm happy you've gone so long on dino oil and I'm sure many can also-with proper oil and filter change intervals.
A few months ago, I very badly overheated my car-I had to drive it off a highway with no coolant. The temp gauge was pinned and it took almost an hour until the block cooled enough to not spit water out as I poured it in. So hot in fact, half the ignition coils went bad.
No damage, knocking, smoke in the exhaust, the engine still runs perfect.
Had I used conventional oil, it would've been roasted to ash and my bearings would've been wiped. Aside from breaking in a freshly built engine, I'll NEVER use dino oil.
Had I used conventional oil, it would've been roasted to ash and my bearing would've been wiped. Aside from breaking in a freshly built engine, I'll NEVER use dino oil.
Most of you guys drive like little old ladys and talk crap.
Some are legit, most are not.
You don't need a syn to be successful with any motor.
You need to be intelligent and not some sheep.
Im with ls6 on this.
I usually just get conventional pennzoil 5w30 every 3k miles. I just have a hard time believing I should switch to synthetic. I like the idea of changing my oil every 3k and not 5k. I also believe its more of a marketing scam.
Do you think they sit back in a big leather chair smoking a tabacco pipe emphasizing on why their so educationaly elite with their Princeton education on motor oils? LOL!
Sorry dood but those are the facts.
You can pretty much buy and other good oil like amzoil or any other synthetic for cheaper than that. Personally I use vr1 10w30 because of its higher zinc content (1360ppm instead of the norm 900ish) or pennzoil ultra depending on which ones available that week.
