Ls intake on an Lq
Old Oct 26, 2011 | 09:15 PM
973800CamaroRS's Avatar
Default Ls intake on an Lq
I know many people have done this but what is an easy way to use a car intake (fast,ls6) on an lq4 with truck accessory's from what I read you can relocate the alternator and get an ls water pump and the intake should fit. Is that correct or is there a better way ? Also with a new intake you would need new fuel rail and injectors, anything else ?
Thanks
Old Oct 26, 2011 | 09:32 PM
zipster's Avatar
Check out my photobucket lq4, ls1 intake, truck rails, and ls3 injectors.
sneak peek
Old Oct 26, 2011 | 09:54 PM
So what all did you replace or mod for the intake to fit and I think I would do an ls3 intake with ls3 fuel rail and injectors. But that will be on l92 heads
Old Oct 27, 2011 | 07:10 AM
zipster's Avatar
The only real mod I did was relocate the water pump outlet. Some have made it work with the truck outlet. The injectors worked, as did the truck fuel rails. I only need spacers to mount the truck rails.
