low oil pressure
Old Nov 2, 2011 | 06:37 PM
pdasterly's Avatar
Default low oil pressure
rebuilt engine, first start oil pressure is normal 40 psi then once engine warms to operating temp pressure drops to 10-15 psi, really low, check engine light might pop on. If i give some rpms the pressure goes up. replaced sending unit with same results. motor sounds healthy
Old Nov 2, 2011 | 10:01 PM
RsSean's Avatar
Bearing tolerances?what oil pump did you put in? Pinched the o ring?
Old Nov 3, 2011 | 12:08 AM
Johnnystock's Avatar
Pinched o ring x2
Old Nov 3, 2011 | 10:17 AM
pdasterly's Avatar
i pray its a pinched ring, has ls1 oil pump
Old Nov 3, 2011 | 10:27 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
I would bet money on the o-ring.
Old Nov 3, 2011 | 12:38 PM
pdasterly's Avatar
can i change to high pressure/volume spring for factory pump, who sells or pn#?
Old Nov 3, 2011 | 12:44 PM
3rdCoastPowerSports's Avatar
if its a pinched o-ring changing to a higher volume spring would be like using a band aid to fix a broken arm. what did it feel like when you installed the oil pump... did you put the o-ring on the pick up tube and then install into the pump?
Old Nov 3, 2011 | 03:24 PM
chrisfrost's Avatar
You can raise the high pressure bypass pressure by putting a cpl washers between the spring and the cap/bolt . But 3rd coast is right ,,,,,,,You need to somehow pull the pick up tube off far enough to check/replace correctly the o-ring ,,,,,,,,,,,hopefully that is the problem as that would be the easiest/cheapest possible problem in You're situation . Good luck
Old Nov 3, 2011 | 05:36 PM
pdasterly's Avatar
shop assembled engine
Old Nov 7, 2011 | 01:21 PM
pdasterly's Avatar
changed oil and pressure went back to 40+. once car warms up to operating temp i lose about half the pressure
