Adjusteble Timing Set
Old Nov 3, 2011 | 05:26 AM
yukio's Avatar
Default Adjusteble Timing Set
Hello.
I am building a H/C/I LS6.
The motor has some miles on it so i want to replace the timing chain. While i am doing that i would like to change to a adjusteble one.
I am looking at the 450+RWHP range.
Does anyone have any suggestions on what timing set to buy?
Is the LS Chain a direct swap?
I would prefere not to swap out the timing cover.
Do i have to do that i i buy a double roller chain?
Thanks
Tommy
Old Nov 3, 2011 | 06:30 AM
Gray86hatch's Avatar
LS2 chain is a good piece. Yank is selling them for less than $70.
Tim
Old Nov 3, 2011 | 07:33 AM
KCS's Avatar
KCS
Moderator
Tim
I don't think those are adjustable.
N Motion/JP Performance make nice billet single roller timing sets that are adjustable to about +/- 8 degrees. They're usually less than $100 and you don't have to clearance the timing cover/oil pump to make it fit either.
Old Nov 3, 2011 | 07:47 AM
First ? Do you have the tools to degree the cam?
Do you need a adjustable chain. The 10 cams I have installed only 1 needed an adjustment.
For the basic install the ls2 fits the bill.
Not worth dealing with spacing the pump and other clearance issues.
Some A/M chains don't last very long.
Tim
Old Nov 3, 2011 | 11:37 AM
vettenuts's Avatar
Cloyes makes the OEM. I like the Cloyes Hex-adjust for an adjustable as it doesn't require pulling the crank sprocket to adjust cam timing.
Old Nov 3, 2011 | 12:13 PM
3rdCoastPowerSports's Avatar
I agree, buy the cloves hex-adjust
Old Nov 3, 2011 | 07:53 PM
yukio's Avatar
Cloyes it is.
Thanks guys.
