crank postion sensor ???
Old Nov 3, 2011 | 02:27 PM
SHibbY01WS6's Avatar
Default crank postion sensor ???
i searched all over and didnt find it so here we go. when i pulled the harness on the a 01 trans am with a 6-speed i pulled the 3 wires from the crank postion sensor and i was wondering if any has a diagram or could tell me were the wires go (ex. pink wire goes pin A, green goes pin B and black goes pin C) i know these arnt the real color but you gett the idea thanks
Old Nov 3, 2011 | 03:14 PM
chrisfrost's Avatar
For the truck engines You have Lt grn coming from ignition and in the center Dk blu/Wht stripe coming from CKP then Yel/Blk from referance low all three of these are from those named pins from the Pcm . I'll have to go out and look at my harness to determine which 1 is first and third if You need ,,,,,let me know
Old Nov 3, 2011 | 05:21 PM
That would be great thanks
