Pushrods are too long
Old Nov 5, 2011 | 01:18 PM
arpell's Avatar
Default Pushrods are too long
What are the consequences? Need 7.325", but 7.4" ones are installed. Will I be okay for say 50 miles if I go easy? Or will it break right away?
Old Nov 5, 2011 | 01:31 PM
Damian's Avatar
LSX Mechanic
What method did you use to determine this?
Old Nov 5, 2011 | 01:35 PM
ZeeOSix's Avatar
How do you know you need 7.325 pushrods if you haven't measured?
What lifters are you running? ... different lifters have different pre-load settings. See attached chart.
You're talking 0.075" difference between what you think you need and what you have. If you are running LS7 lifters, you might get away with it for a while since they have lots of plunger travel.
Old Nov 5, 2011 | 01:42 PM
arpell's Avatar
Pushrod length checker. 9.5 turns. 0.50 preload needed for Lunati linkbar lifters. Checked EO/IC and also at 45-degrees past intake closed. Checked four cylinders. Pretty confident in results. They were all 6.80 + 9.5x0.050 + 0.050 = 7.325".
Old Nov 5, 2011 | 02:32 PM
ZeeOSix's Avatar
If you measured and determined you needed 7.325" pushrods, why didn't you get some and put them in when it was apart?
Old Nov 5, 2011 | 02:54 PM
R6cowboy's Avatar
I don't know why you have 7.4" installed when you know 7.325" is needed, but I don't care. It would be nice, not to mention helpful, for someone that knows to answer your question, not question you. Knowing its off .075", I wouldn't run it at all until I know for certain if its ok or not.
Old Nov 5, 2011 | 03:12 PM
ZeeOSix's Avatar
Can't give any kind of real answer without some questions first. He did say he's running the "Lunati linkbar lifters" ... so not sure what the total plunger travel is on them.
He also now divulged that his zero lash measurement with adjustable pushrod is "6.80 + 9.5x0.050", which gives a zero lash pushrod length of 7.275". If he's running 7.400" pusrods, then his pre-load is 7.400 - 7.275 = 0.125".
So ... if the total travel on these Lunati lifters is somewhat larger than 0.125", then he's probably not bottoming them out but could be close. If he had LS7 lifters, then he'd be safer for now since they have a total plunger travel of 0.166".
Old Nov 5, 2011 | 04:05 PM
arpell's Avatar
At least now I have an idea of what to search for with respect to the Lunati street rollers I am running - total plunger travel. If they have >= 0.125 travel, it shouldn't be too bad, just not ideal.
Just finished buttoning-up my new top end and would like to start trying to tune it or at least see how it runs. Will order the right-size pushrods today, but have had a few setbacks and would like to get this thing running. Am anxious, but not reckless.
Old Nov 5, 2011 | 04:33 PM
ZeeOSix's Avatar
Expect to hear some lifter noise until they get fully pumped up. But yes, try to find out what the plunger travel is on those lifters before starting just to be sure you're not already bottoming out the lifter with your 0.125" pre-load.
Old Nov 5, 2011 | 08:05 PM
Cooldude5231's Avatar
i wouldnt take a chance personally
if the valves are to big youll totally bottem everything out.
too big of a risk if you ask me.
better to do be patient the first time.
or youll be waiting even longer the second time around.
Old Nov 6, 2011 | 11:11 AM
NY02ws6's Avatar
valve size has literally NOTHING to do with lifter preload or pushrod length
Old Nov 6, 2011 | 06:14 PM
R6cowboy's Avatar
I wonder if they meant push rod length instead of valve size, because I can't see how valve size could make sense.
OP, it's probably not in best interest to see if the wrong piece will work or "be ok". I think you should be patient and do what you know is right the first time. Good luck either way.
Old Nov 6, 2011 | 09:37 PM
arpell's Avatar
Thanks for all of the replies. I will wait until the 7.325" pushrods are installed before starting and running it. I did everything else to the best of my ability on this build, so it would make no sense to try something that would possibly damage my engine.
