Stock cube nitrous build Question
Old Nov 6, 2011 | 12:04 PM
charlie97z28's Avatar
Default Stock cube nitrous build Question
I'm wanting to do a stock cube heads and can nitours build I got a v3 cam and ported set of 241. What would the best piston to go with? And should i put a set of rods in it or jus swap out the pistons? Keep in mind the whole reason behind this is to use what I got and be a budget build.
Old Nov 6, 2011 | 01:30 PM
99 PROBLEMS's Avatar
how much n2o you plan on spraying?
Old Nov 6, 2011 | 04:26 PM
Some where around a 200 shot jus depends on what it does on motor I looking for something around low to mid 6 sec range in the 1/8th
