New headers eating through new spark plug wire
Old Nov 12, 2011 | 12:52 PM
Xaero1701's Avatar
Default New headers eating through new spark plug wire
Two days ago I had my Pacesetter LT headers installed along with some RPM Speed 10.2mm spark plug wires. Today while looking under the hood I noticed one of my wires is hugging part of the header and has melted all over it. I took the plug off and its melted through the casing to nearly expose the wires. How do I stop this wire from touching the header? The other 7 wires are fine its only this one that doesn't want to do anything other then lay on the header. If the boot wasn't to long I think the wire would be fine. Would a diff brand of wires be better or was it just placed on wrong?
Also wouldn't the shop that installed this be responsible for replacing the wire?
Old Nov 12, 2011 | 02:16 PM
98TAjwh's Avatar
there are heat protectant "socks" that are readily available at most auto part stores. i used them on my wires when i put my pacesetters on just cuz they looked close. i've since taken off the pacesetters and just left them on just for the added insurance. never had a wire melt.
as for the shop being accountable, you asked them to put the long tubes on and they did. not sure if you can hold them responsible for the wire melting, but it never hurts to ask.
Old Nov 12, 2011 | 02:53 PM
mpatton's Avatar
Turn the boot so it kicks that wire away from the header. Also the socks wouldn't hurt
Old Nov 12, 2011 | 03:25 PM
gMAG's Avatar
If turning the boot won't fix it, try looking for a 45 deg, or 90 deg boot, instead.
A search for '45 degree sparkplug wires' on Google will give you several maufacturers, or try ebay.
Old Nov 12, 2011 | 03:56 PM
Xaero1701's Avatar
Thanks for the advice guys. I will search for the degree wires and get those socks too.
Old Nov 12, 2011 | 04:17 PM
01ssreda4's Avatar
MSD wires with bend-able boots
