228r cam/Head Combo questions
Old Nov 18, 2011 | 08:04 AM
Bigredmachine's Avatar
I don't wanna stay with the 241 heads. I think it'd be a waste of money to get them ported and done up. My plan was to get the 243/799 heads and get a valve job and some port work done. I can't go crazy because I don't have a ton of money but I am fairly certain that if I get some mild port work and a valve job I would exceed the performance of a set of fully ported 241s. And it would make it a whole lot easier to do a head and cam swap all at once rather than pull off my 241s and send them out. Just my .02
Old Nov 18, 2011 | 09:54 AM
Rare96LT1Formula's Avatar
With the cost of a used set of 243's and a decent valve job, you might be better off re-working those 241's. Send them off to AI and have yourself a quality set of heads imo.
Old Nov 18, 2011 | 10:18 AM
sittinlovely's Avatar
I have a set of 799's for sale if your interested. Let me know
Old Nov 18, 2011 | 10:59 AM
Old Nov 22, 2011 | 06:43 AM
After talking with Aaron from Texas Speed I think I'm gonna go with the 233/239 cam on 112 with a set of 243/799 heads. That should definatly hit the numbers I'm looking for.
Old Nov 22, 2011 | 08:42 AM
I'd have to disagree with that. You're going to spend $400ish on the 243's then another few hundred bucks to get them done up nice. This doesn't even take into consideration the condition of the valves,etc.
I'd get the 241's done up, but that's just my opinion. Advanced Inductions ftw. Heads are not the area you go cheap!
Old Nov 22, 2011 | 11:48 AM
I can get a good deal on the heads and I'm not getting them all out full ported but even a little bit of porting and a valve job would still be a few hundred under the $1000 plus that it'd take to do the 241's. And like I said I wanna do this all relatively quick, so I won't have time to pull off the 241s and send them out for a couple weeks and its certainly not worth buying another set to me..
Old Nov 22, 2011 | 01:09 PM
Ronny_02_WS6's Avatar
I would go with PRC 2.5 LS6 heads and Torquer V3 as stated above but if you cant afford it go with torquer v3 and ported 243's.
Old Nov 22, 2011 | 06:53 PM
How streetable is the Torquer V3? Is there any kind of significant power gain over the 233/239 cam? Im dead set on the 243/799 heads. i already have a set of 317's but im trying to sell or trade for some 243s or 799s
Old Nov 22, 2011 | 09:34 PM
How would you compare the TSP 233/239 on 112 to the Torquer V3 as far as driveability, power difference, power band, roughness of idle,etc.
Old Nov 22, 2011 | 09:41 PM
msydow's Avatar
just saw your question. yes both cars have stock 241 heads. my 98 made 426 with an MS4 and stock 853's. cody doesnt daily his car with the V.3 but he could no prob (six speed). he loves his. so does steven with tsunami. he pretty much drives his everyday (stalled auto).
Old Nov 22, 2011 | 09:53 PM
  #32
t5munoz's Avatar
Im going with a 228/228 .588 .588 114lsa and some mamofied AFR heads and im looking at 450 but im sure i will get more i hope!!!
Old Nov 23, 2011 | 08:53 AM
  #33
I'm going to stick with the TSP 233/239 112lsa cam. After talking to Aaron at Texas Speed comparing that cam to the Torquer V3 he said the 233/239 cam will make more power.
