oil pressure issue
Old Nov 16, 2011 | 06:41 PM
n2ols1cam's Avatar
Default oil pressure issue
i have a ls1 with a ms4 cam and milled 243 heads. it has a slp oil pump and im haveing a little problem. when i cold start the car it has good oil pressure (idles 60psi) but when it gets warm and ive been driving it around for a while it idles at 20psi and drives around at 25-30 psi and when i go WOT it only gets up to 40psi all the way up to 7k rpms. any ideas? is my oil pump messed up?
Old Nov 16, 2011 | 07:37 PM
1lejohn's Avatar
Its not really low. Maybe just a bit at wot. Try a thicker oil and see what happens. How many miles on the engine.
Old Nov 16, 2011 | 07:41 PM
Daniel0026's Avatar
Is there a chance one of the cam lobes got scratched in the install? That can kill oil pressure in a hurry. You could also try a simple volt meter test on the pump to see if it is a power issue if you think its the pump. (just try the simple things before stuff starts flying out of the engine bay and onto the workbench...)
Old Nov 17, 2011 | 09:31 AM
n2ols1cam's Avatar
there are around 1500 miles on the engine. forged pistions and rods. there is mobil 1 10w-30 in it now, you think i should go thicker?
no there isnt but i did have a collapsed lifter and i replaced the lifter and the cam. when i took the old cam out there wasnt any scratches on it accept for one lobe so i only replaced on lifter.
Old Nov 17, 2011 | 04:08 PM
Daniel0026's Avatar
If you put a heavy oil in, you will see an overall increase in oil pressure 5-10 psi above what you have right now. Now with this fix the issues you are having?: Im not sure. You can try it and see because thats only $20 to narrow down your problem...
Old Nov 17, 2011 | 04:25 PM
n2ols1cam's Avatar
well hopefully that fixes the problem. ive heard that with the slp oil pumps they are higher velocity than stock so they tend to drop a little oil pressure because the hole is bigger. is this true?
Old Nov 18, 2011 | 03:42 AM
ls1 1990 VN's Avatar
You guys get a German Castrol...use it. go for a 5 or 10w-40
Best oil Royal Purple
