Head Gasket?
Old Mar 12, 2004 | 05:26 AM
Z06Ron's Avatar
Default Head Gasket?
Why are the 97-01 and 02-04 head gaskets different? I just noticed they had a different part number. Does anyone know the difference and what problems you will run into if you get the wrong one?
Old Mar 12, 2004 | 11:44 AM
Z06Ron's Avatar
I have a 02 block with 01 heads. It seems the <01 has a right and left where the 02< does not.
Old Mar 12, 2004 | 12:46 PM
slick98ta's Avatar
97-01 uses a graphite gasket
02-03 uses a multi-layer steel gasket
Old Mar 12, 2004 | 12:50 PM
1QUIKWS6's Avatar
Active Streak: 30 Days
slick98ta is correct. Usually you cannot use the multi-layer gaskets on a car that was originally equiped with the graphite gaskets.
A sure fire way of knowing is: if your head sealing surface has a machined half moon cutout in the center along the one edge - the multilayer gaskets will leak like a seive.
Old Mar 12, 2004 | 12:57 PM
99huggerorangeZ's Avatar
Question
Originally Posted by 1QUIKWS6
slick98ta is correct. Usually you cannot use the multi-layer gaskets on a car that was originally equiped woth the graphite gaskets.
how about copper gaskets?
Old Mar 12, 2004 | 02:13 PM
slick98ta's Avatar
1QUIKWS6 is right about putting a multi-layer gasket on a pre 02 car.My friend put them on his 98' and it did leak.
