Ms3 cam degreeing?
Old Nov 20, 2011 | 09:30 AM
jdzo6c5's Avatar
Default Ms3 cam degreeing?
I have the MS3 cam and also ordered the LS6 2.5 stage prc heads combo. I dont know if im able to advance the degree of timing or if I have to leave it at 0 degrees for PTV clearence? Anyone have experience with this?in sure this is a popular combo. I just wanted to adv timing to get more power in the lower rpm band for the street. Thanks.
Old Nov 20, 2011 | 10:13 AM
JS01's Avatar
Best way is to just go ahead and check PTV with a degree wheel, checking spring and dial indicator on the retainer or valve tip. Better safe than sorry.
Old Nov 20, 2011 | 01:23 PM
95ONE's Avatar
Are you looking for more advance than what was already ground in? Probably around 2+ degrees.
Old Nov 20, 2011 | 07:52 PM
badazz99ss's Avatar
I installed mine at dot to dot thats what was recommended
