Take a guess
Old Nov 20, 2011 | 08:17 PM
99slobird's Avatar
Default Take a guess
My car is a 99 TA with a 383 stroker, ported 241s' ms3 cam, 102/102 intake, ud pulley, lid, 1 3/4 lts, x pipe ran out the back. It has a th350, 3000 stall, 12 bolt with 3.73 gears on a 28 inch tire. The car made 432 hp on motor and 548 on a very conservative nitrous tune by lane at hinsons. The only things I am changing is taking them 241s off which makes my car have a 10.3.1 cr and putting on a set of tfs 225s with roller rockers and getting my cr to about 11.1 What do you guys think the car will make on the Dyno with the head and rocker arm change????
Old Nov 21, 2011 | 06:41 PM
crainholio's Avatar
One zillion horspowerzzzz!!!!1!!one!!1
Old Nov 21, 2011 | 07:07 PM
prokilllsx's Avatar
468 na
Old Nov 21, 2011 | 07:25 PM
99slobird's Avatar
I was just wondering what to expect. I did want to get my hopes too high and be disappointed on the Dyno. And I thought some of you might have some experience with a similar setup
Old Nov 21, 2011 | 09:08 PM
09camaro383's Avatar
i have dart heads 225cc ported static compression ratio is 11.1 and dynamic compression ratio is 8.1 z28 dyno 489
