LY6/L92/LS3 head question...
Old Nov 22, 2011 | 06:31 PM
Doug G's Avatar
Default LY6/L92/LS3 head question...
Hope this isn't a repete
Will the rockers and stands from other LS motors fit the LS3 heads ????
I want to upgrade with the rebuild of the LQ4
Old Nov 22, 2011 | 08:23 PM
A.R. Shale Targa's Avatar
In order for GM to fit a 2.165" intake valve they had to tweak the valve
spacing. I believe the stands and the exhaust rockers fit but you'll need 8
offset GM intake rockers.
Old Nov 22, 2011 | 09:54 PM
MX6.0's Avatar
Needs LS3 rocker stands also.
Intake rockers 12569167 x8
LS3 Rocker stands 12600936 x2
Old Nov 23, 2011 | 06:14 AM
Doug G's Avatar
Well that kills that idea
I was going to get the LS3 heads and swap over the rockers.......guess i'll need to find a pair of used complete (good) heads
Thanks
Old Nov 23, 2011 | 08:11 AM
MX6.0's Avatar
Thanks
The LS3 rockers are only $10 each and the stands are $7.50 each. You can have brand new fully assembled LS3 heads ($630 for the pair) and the new rockers/stands for $725. Factor in what you can sell your existing heads for and the deal only gets sweeter.
Old Nov 23, 2011 | 08:35 AM
streetknight2's Avatar
Where can you get the heads for that price? I checked with my dealer and the heads cost them 393.00 each, but on backorder I was told.
Old Nov 23, 2011 | 11:01 AM
MX6.0's Avatar
I got mine from Pace about a month ago. I couldn't believe the price either.
Last edited by Patrick G; Nov 23, 2011 at 06:17 PM. Reason: non-sponsor link removed
Old Nov 23, 2011 | 12:09 PM
Doug G's Avatar
OK.... so if I get the heads from Pace $650....get 8 intake rockers @ $80...and get ???how many stands ?? 8 ?? @ $7.50.....
Looking now
Old Nov 23, 2011 | 12:23 PM
MX6.0's Avatar
Looking now
2 stands. 1 per head
Old Nov 23, 2011 | 12:31 PM
Now the LS3 head has a D shaped exhaust port, correct? That is different from the L92 head and requires different headers doesn't it or am I wrong as usual lol
Old Nov 23, 2011 | 12:48 PM
MX6.0's Avatar
As far as I know the LS1,2,3,6 all share the same exhaust ports. L92 being the same as the LS3 aside from different intake valves (hollow vs. solid).
I know LS7 and LS9 are different but I'm pretty sure the rest are equal as far as exhaust ports go.
Someone correct me if I'm wrong, I'm fairly new here
