loose chain??
Old Nov 24, 2011 | 12:35 PM
bugy's Avatar
Question loose chain??
i've seen some, almost all LS-series engines have loose gear chain, is this just a wrong or worn chain?? or this is normal on these engines for something, i dont know maybe something regarding perfomance...
Old Nov 24, 2011 | 07:21 PM
2000PewterT/A's Avatar
Well most of the chains you saw were probably worn out. Also I have never seen a loose timing chain for performance.
Old Nov 25, 2011 | 11:06 AM
NY02ws6's Avatar
define loose...
Old Nov 25, 2011 | 11:30 AM
3rdCoastPowerSports's Avatar
on all the LS motors i have taken apart the chain has been "loose". it doesn't make any sense to me but they seem to be that way. you can go with an aftermarket timing set that will help reduce the "looseness" of the chain... i've heard Rollmaster is a nice "tight" set
Old Nov 25, 2011 | 04:19 PM
bugy's Avatar
yeah, in fact i already did it by "cloyes" aftermaket and it is tight enough to work nice, just that issue came to my mind if it comes from OE factory with the slack timing chain, but it doesn't make sense for perfomance... anyway thanks guys.
