symptoms of broke spring??
Old Nov 24, 2011 | 08:38 PM
los p's Avatar
Default symptoms of broke spring??
what are the symptoms of a broken spring? the heads and cam have about 20,000 miles on them since installed
Old Nov 24, 2011 | 08:43 PM
Sales1@Texas-speed's Avatar
If you suspect any kind of issue remove your valve covers and check for any damaged or broken springs.
Old Nov 24, 2011 | 09:06 PM
los p's Avatar
ok i will do that but when i take the covers off can u just look at them and can tell or u have to take each one off and check or it varies
Old Nov 24, 2011 | 09:31 PM
ZeeOSix's Avatar
If you have a broken spring, you'll be able to see it by just taking off the valve cover.
Old Nov 24, 2011 | 10:05 PM
mbaker3's Avatar
If you drop a valve, .............the carnage that will follow will be unbelievable! You should check this out rightaway!
Old Nov 25, 2011 | 01:05 AM
ZeeOSix's Avatar
If you have double springs, you might have to take the springs off in order to see if any inner springs are bad. If you have beehive springs, then you should easily see any broken springs.
