Head gasket ? Need help
Old Nov 26, 2011 | 01:39 PM
sittinlovely's Avatar
Default Head gasket ? Need help
So I just bought some afr 205 heads, they have been milled to 58cc. When I recieved them I took them to a local speed shop. They said they would need to be milled again to clean up whoever milled it last. Is there anyway I would be able to get a head milled and then get a thick head gasket to make the final cc around 60-62? Would this cause any problems? Thanks in advace
Old Nov 26, 2011 | 02:07 PM
crainholio's Avatar
You'll be giving up a lot of quench area raising the heads farther off the deck, making the engine more prone to detonation. I'd return the heads.
