Old May 20, 2016, 12:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Engine Problems by Symptom
Print Wikipost
Misfire under load
Old Dec 4, 2011 | 09:33 PM
bones_c's Avatar
did a brake torque and no miss.... im going with the torque converter trying to lock and unlock because like said only at a cruising speed and not all the time... i realized today that sometimes i have to push the throttle at least half way before the car will down shift to third or second. I want to buy a Yank 4000... will this fix my problem? i know this is the wrong section for this question...
Old Dec 4, 2011 | 11:02 PM
lemkerailroad's Avatar
i am glad that i can help out here
i just hate guessing with out driving it like was said
but somethings so small i forget about untill someone kicks me in the but also
glad i can help out though
keep us posted as to what you found out please
dave
Old Jul 25, 2023 | 10:36 PM
Gfolk23's Avatar
I have a 4.8L LS from junk yard, we hanged plugs, and coils and fuel pump and filter. Everything is installed correctly it will do 1st and 2nd gear find but higher rpm’s around 3-4k it seems to break up and misfire it sounds like I have a rev limiter which is not the case. Not sure if it’s the tune or a bad motor. I have yet to check MAF which we took from anoth junk yard 5.3 it could be anything
