Advice Needed on Engine Package
Old Dec 6, 2011 | 03:00 PM
Ronny_02_WS6's Avatar
Originally Posted by maxpower_454
I agree with changing the timing set but I thought the 01-02 had a good oil pump from the factory. I'm all for more oil flow but more than you need is wasted horsepower.
Yup, you should be fine with the 02 factory oil pump, they where made better than the 98-00 also the lifters too! It also depends on how many miles you have in it.
Old Dec 7, 2011 | 07:58 AM
maxpower_454's Avatar
76k miles. I figure I can probably just change it at 100k. I'm sure I'll end up changing it with the cam swap though if it'll help prevent a spun bearing....
Since I'm in no hurry to change heads/cam with winter already here, I'm goign to see if I can find a set of ported 243 heads in the classified or on the bay and then have a machine shop check them before install. I really only want to do this stuff once. If I drop about $1300 on those that leaves me about $700 for the cam swap. Since the heads will probably come with aftermarket springs, I think I'll be within my budget.
Old Dec 7, 2011 | 12:40 PM
Rise of the Phoenix's Avatar
Vengeance has a head/cam package that's pretty killer. TFS 220 as cast heads, all the gaskets you'll need, upgraded rockers, pushrods, cam, etc. The last time I looked, it was a little over 2 grand. If you're going to do it, then do it right. Get some proven heads that will perform well and get you to your goal. 450 rwhp and a fat *** torque curve is definately possible with the TFS 220 as cast heads and the right cam.
Old Dec 8, 2011 | 09:51 AM
It's around 3k now.... Looks like they had a sale on it a while ago for $2.5k
With the cost of heads/fast intake/TB, I might be better off with a procharger.
Old Dec 8, 2011 | 12:48 PM
Yeah, but Heads/Cam/Intake and Procharger are two different beasts. Both are beasts though.
Old Dec 8, 2011 | 06:49 PM
allout06's Avatar
+1 for the procharger.... but im biased
Old Jan 13, 2012 | 10:08 AM
Allout, are you running a stock bottom end? What about heads? Does the torquer v3 work good with the blower? I'm thinking about that cam for now and might go with a procharger down the road. I'd rather not have to swap the cam again if I ever end up installing the procharger.
