6.0 install...Help!
Old Nov 29, 2011 | 01:46 PM
IMPRTKILLER's Avatar
Default 6.0 install...Help!
I had a LS1 in my camaro and blew it up. I got a 6.0 liter from a 2006 GTO and was wondern what i need to do to put it in my car. I see the LS6 heads i have will fit this motor but wondern about my cam. My cam is a magic stick 3 603/609. And i also se it doesnt have knock sensors like my LS1 did. Do i not use that harrness anymore? Please help me!!!
Old Nov 29, 2011 | 02:44 PM
dodson55's Avatar
you have to have extension harnesses for the knock sensors they mount on the side of ls2 and cam sensor mounts in the timing cover of an ls2 i think they are around 60$ for them the car has the ls2 has the same heads as a ls6 except they have solid valves and yes you ms3 will fit rite in
Old Nov 30, 2011 | 02:53 AM
Thank u dodson55...i just bought the harness from texas speed. Now cant wait till summer
Old Nov 30, 2011 | 03:35 AM
slow_5.0's Avatar
I've been looking into doing this swap and i think you need somthing to read the crank sensor as well. It either has more teeth or less teeth not sure on the 6.0
Old Nov 30, 2011 | 09:49 AM
NemeSS's Avatar
Sounds like it's a possible 58x ls2. Which needs a few parts and electronics to run in a 98-02 fbody
Old Nov 30, 2011 | 10:11 AM
dodson55's Avatar
not if its a gto it has the same wheel as a ls1 any ls2 06 up except a gto has the 58 wheel
