Benifits of honing
Honing a cyl is normally done to correct these:
1. Establishes the correct 45 degree crosshatch pattern in the cyl bore for proper ring pack to bore seal after a bore bar has been used on the block.
2. De-glazes the bore (performed on older engines that don't require a rebore.
3. Assures exacting cyl bore shape
4. Honing can be adjusted to correct for exacting cyl bore to piston tolerances when fitting new pistons in a block that has just been bored.
I would think that a new GM block would not need any honing when stock dimension pistons are used. They are manufactured with the correct crosshatch and stock piston to bore tolerance.
With your aftermarket pistons... Well, honing [may] be needed if the piston to bore clearance needs to be slightly changed.
Ron,
1) How many miles are on the engine? If it has very many miles, it might be good to hone it a tad to make sure the rings seal right.
2) How good is the "before 0.005" hone? (kind of relates to #1)
3) Does it cost more to get "factory" sized pistons or does it cost more to hone and get +0.005" pistons? (might get a deal on the oversize ones)....
4) Do you care if its no longer a 346 CI engine? I know....sounds stupid but there are people who would care (perhaps the class your racing in requires factory displacement).
Chris
<small>[ March 02, 2003, 05:31 PM: Message edited by: 2001CamaroGuy ]</small>
Thanks,
Chris Gelineau
Diamond Pistons
877-552-2112 toll free
I did buy a new LS6 crate block, but elected to get 3.905's since they are more off the shelf, and it's a popular size.
