? about ms4
Old Dec 13, 2011 | 08:39 PM
tillery's Avatar
Huge improvement. I put them on as cast. Milled for more compression and .040 cometics. Im running Yella Terra rockers and a 7.5 PR. I also have a -4cc piston so its why I could get away with the MS3 and the PRC 2.5 LS6s before. For the price the TF220s cant be beat. If anything a little port work mainly to clean up around the valves could be done and thats it. My car is a M6 with 4:10s and its a blast to drive on the hwy. I need a better tune for better drivability. If you are to run stock rockers. I believe you have to run a factory type guides. Also measure PR length cause so many different variables. I say get them and you won't be disappointed.
