Need input.
Old Dec 24, 2011 | 01:11 PM
mmarty71's Avatar
Default Need input.
Hi, I know I've asked this but I have a stock 01 lq4 and new 4l60e sitting here for my 86 firebird. I can't swing the cash for a cam swap (to do it right anyway) but I want to get the car running. How do you think It'll run stock? I had a ls1 intake and 30lb injectors gave to me so I am going to use them. I have a line on a cheap F body oil pan and pickup from a buddy that can also tune it for me. Any info would be appreciated.
Old Dec 24, 2011 | 10:56 PM
A.R. Shale Targa's Avatar
If funds are low run it. With 3.42/3.73 gears it should still move out nicely.
Old Dec 25, 2011 | 06:57 AM
Paul57's Avatar
This would make a very nice improvement if you don't have one already... http://revmaxconverters.com/torque-c...e-1999-stage-3
They are cheaper than a new cam.
Converter and Cam...the first two things you should do to an LSx ride...in that order.
Old Dec 25, 2011 | 03:45 PM
mmarty71's Avatar
Thanks a bunch, Since the stock cam is so small what converter should I go with? 3000 stall? I have a ford 9 already made for the bird with 3.55 gears but also have a set of 3.89s if I need. What is the range for that cam? I would figure to be idle to 5500.
Old Dec 25, 2011 | 09:22 PM
3000 stall and the 355s should be a nice streetable combo and set you up
well for a cam swap in the future. Yes the stock cam will be done by 5500
