Clean the pistons?
Old Jan 2, 2012 | 08:49 PM
RealLiveMD's Avatar
Default Clean the pistons?
Doing a head swap. I noticed everyone shines the pistons. Why take the time? Am I missing something? Just want to get er done.
Old Jan 3, 2012 | 04:17 AM
vettenuts's Avatar
Carbon can cause detonation.
If measuring PTV, carbon can give false values.
Old Jan 3, 2012 | 05:46 AM
BOBS99SS's Avatar
Captain Double Post
^this x 2,
Old Jan 3, 2012 | 07:09 AM
Steve Gunn's Avatar
Scotchbrite pad and carb cleaner. Cover your fenders.
Old Jan 3, 2012 | 11:28 AM
getusumws6's Avatar
Agree with above. Cleaning the pistons is good towards measuring PTV and or flycutting, which most people do when they take the heads off to replace them.
Old Jan 3, 2012 | 10:22 PM
RealLiveMD's Avatar
I'm just changing the lifters. I took the heads off to track down a valve train problem. Now that I have my heads and springs repaired I just want to get them back on. Im catching hell trying to clean the block. The blue scotch Brits pad leaves blue felt in all the ports. I can't find a roloc anywhere. Also I have a dremel and tried the little felt pads bit they keep burning off. There has to be an easier way.
Old Jan 4, 2012 | 04:16 AM
vettenuts's Avatar
Try a local paint store. I found non-metallic scotchbrite pads there that worked well and they were available in different roughness.
