machine shop question
Old Jan 5, 2012 | 07:52 PM
97badass's Avatar
Default machine shop question
More like questionS
Anyways I got my heads in today for my lq4...
L92s that are being smoothed in the runners but how much should I have them milled for a 10.5:1 compression using stock lq4 pistons and stock head gaskets? Also am I going to have ptv issues with my 229/236 .623 .617 112 lsa cam?
Old Jan 5, 2012 | 08:50 PM
97badass's Avatar
i ahte to bump so soon, but i need to know since i will dropping them off tomorrow for him to do the work
Old Jan 5, 2012 | 11:04 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
You sure might, how much are you milling? We have the prc port and valve jobs setup to help p/v over a stock head allowing us to mill a little but with cams similar to that one.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jan 5, 2012 | 11:08 PM
97badass's Avatar
Hey bud, your the one I talked to on the phone when I ordered the cam... I'm not sure how much to take off to get my c.r. some say .030 for a 10.8:1 which is fine for me. I've got an extra head to use for flycutting...
Old Jan 6, 2012 | 02:19 AM
bww3588's Avatar
With stock dish pistons your going to be hard pressed to get it That high and not run into the huge intake valve. For this reason alone I went with a flat top with reliefs.
Old Jan 6, 2012 | 07:14 AM
97badass's Avatar
Those will come the next go around, right now I'm trying to get this thing going good and strong then go big cubes in a couple years when I can afford the built bottom end.
Old Jan 6, 2012 | 07:15 AM
97badass's Avatar
