How to remove oil pressure switch on back of block?
Old Jan 7, 2012 | 10:01 PM
RealLiveMD's Avatar
Default How to remove oil pressure switch on back of block?
My switch was boken on a head swap. I can probably get the broken one out with some pliers but I can't find a deep enough socket to replace it.
Old Jan 7, 2012 | 10:03 PM
Tyrel2018's Avatar
advance auto has a rent a tool program and they should have a sensor socket that will fit
Old Jan 7, 2012 | 10:09 PM
wildcamaro's Avatar
yea there is a special oil sensor socket just for it, or use a gear wrench
Old Jan 7, 2012 | 10:38 PM
98ws6blk's Avatar
What they said...special socket. I had to buy mine. : (
Old Jan 7, 2012 | 11:04 PM
MrElectric03's Avatar
Picked up my oil pressure sensor socket at autozone for $10 or so, its a must have for GMs.
Old Jan 8, 2012 | 04:54 AM
RezinTexas's Avatar
If you get a 27mm deep socket, then it also works for the ARP crank bolt.
Old Jan 8, 2012 | 10:56 AM
NVR_SPDS's Avatar
The LS1 oil sensor is alot taller than that sensor.
There is a specific socket for it, and IMHO its worth buying. Its around 10.00 like was stated before. Just look for a GM oil pressure switch socket.
Old Jan 8, 2012 | 03:57 PM
RezinTexas's Avatar
ahh, ok. the one I posted is from a truck motor.
Old Jan 9, 2012 | 07:32 PM
NVR_SPDS's Avatar
Heres the LS1 Sensor for reference.
