Correct part # for coolant plus for ls6
Old Jan 9, 2012 | 11:02 PM
xdanny510x's Avatar
Default Correct part # for coolant plus for ls6
Ie this the correct part # for the Rear coolant plugs for ls6 intake man fold .... Here is part number 12602540
Old Jan 9, 2012 | 11:18 PM
wildcamaro's Avatar
20-12602540 GM rear coolant Plug - (2 req'd)
20-12602544 GM front crossover pipe assembly - (1 req'd)
Old Jan 10, 2012 | 09:01 AM
ws6man29's Avatar
Default ls6 intake swap
If I swap my ls1 intake to the ls6 intake and I have the throttle body bypass done can I do away with the collant lines underneath the intake?This way I will not have to chizel the intake or buy new ls6 collant lines?
Old Jan 10, 2012 | 09:42 AM
redbird555's Avatar
no you cant, you either need to chizel off the fins or get the coolant plugs mentioned above. The tb bypass just puts coolant through the t while the cooling lines under the intake flow coolant through the heads.
Old Jan 10, 2012 | 10:42 AM
ws6man29's Avatar
Thank you,
so I plug the back and chip the fins off.
Old Jan 10, 2012 | 03:32 PM
99Bluz28's Avatar
Originally Posted by ws6man29
Thank you,
No, if you chip(dremel preferred) the fins off the LS6 you just keep the LS1 coolant lines(preferred), and if you use the the LS6 plugs/coolant line you don't need to remove any fins on the bottom of the LS6 intake.
Old Jan 10, 2012 | 03:40 PM
BADBOB's Avatar
whats the part number for the ls1 crossover that goes to all 4 locations? im looking for one!
Old Jan 10, 2012 | 03:42 PM
ws6man29's Avatar
Thank you for the info.Im going to tackle this once I get my throttle body from Potz Performance.I have the ls6 intake waiting on the tb.What is your thoughts on bigger mass air flow ends?I know changing the maf is a waste of money and time and that the stocker maf can withheld up to 600hp but do you think bigger maf ends are worth it?
Old Jan 10, 2012 | 04:51 PM
99Bluz28's Avatar
No, stick with the stock mafs.
Old Jun 4, 2012 | 10:07 PM
htwhls19's Avatar
what happens if you put plugs on all 4 corners?
Old Jun 13, 2012 | 11:55 PM
parks450's Avatar
The air in your heads will not be able to bleed out causing over hearing issues.
