Which valve springs?
Old Jan 12, 2012 | 08:28 AM
  #41
TurboBuick6's Avatar
Yes in a sense. Unfortunately we do not know customers driving styles so just have to assume everyone bumps the red line like meself of 80% of shifts lol. This is where proper valve spring installation becomes crucial. Unstable spring tend to destroy themselves or just loose pressure pre maturely.
Old Jan 12, 2012 | 12:26 PM
  #42
bstuby's Avatar
Originally Posted by sweet99ss
I don't know why you would go with patriot springs though. There are much much better springs out there. The longevity of the patriots isn't that great from what I hear. I would just go with the pac single springs.
Those are the springs the member who had the cam before me ran without any problems, and I called EPS earlier he said to run pac dual's, patriot dual's, or pac 1518/1519's with this cam. He would rather me run the dual's more than anything.
Old Jan 12, 2012 | 12:28 PM
  #43
bstuby's Avatar
Originally Posted by wildcamaro
I'd say that as long as you dont run higher than a 224 cam you shouldnt have to worry about shimming (although you should always check coil bind agreed), its the bigger cams where that really becomes a factor, am i correct in assuming this turbobuick?
My cam is quite a bit bigger than a 224
Old Jan 12, 2012 | 12:33 PM
  #44
A lot of people are affraid of beehive springs. You lose that safety margin. Well yeas and no. You break an outer under high RPM the valve is toast still.
Old Jan 13, 2012 | 08:14 AM
  #45
wildcamaro's Avatar
Yea I kno that cam is bigger I was soon a lil thread hijack lol...
I would def run dual springs in a stick car bc it's so easy to over rev, but in an auto car wit cam under 600 lift the beehives are fine
Old Jan 13, 2012 | 08:55 AM
  #46
bstuby's Avatar
Ended up going with pac dual's from EPS.
Thank you everybody for the help!
Old Jan 13, 2012 | 09:32 AM
  #47
wildcamaro's Avatar
Good choice
Old Jan 13, 2012 | 10:35 AM
  #48
JPH's Avatar
JPH
Very good choice.
