is this sound normal**vid inside**
Old Jan 13, 2012 | 11:26 AM
ws6outlaw's Avatar
Default is this sound normal**vid inside**
trying to decide if this is just the noisy sewing machine sound that ls1's make or if it's something to worry about. just some info it does this when cold but after about 5 or 10 min to warm up it stops and quiets down.
http://youtu.be/yie0m5HMQSo
Old Jan 13, 2012 | 03:29 PM
ls1 1990 VN's Avatar
That sounds like your accessory belt tensioner is weak. I think you will find that your belt will start squealing in time when cold. Just my thoughts as It sounds like mine did.
Old Jan 13, 2012 | 03:49 PM
1nasty86's Avatar
Turd Gen Guy
piston slap?
Old Jan 13, 2012 | 04:17 PM
ws6outlaw's Avatar
i was thinking maybe piston slap but i read somewhere that these cars are particularly noisey with a sewing machine-like sound. and when it warms up it goes away which could explain very slight piston slap if the rings are heating up and expanding to make everything fit right
Old Jan 13, 2012 | 04:43 PM
Andy fortner's Avatar
what rockers mind done that when a stock rocker started to come a part
Old Jan 14, 2012 | 12:50 AM
ws6outlaw's Avatar
i have no idea about the rockers. im not sure if they have ever been changed. i do know the car has an ms3 cam in it. it was in it when i bought the car
Old Jan 14, 2012 | 07:51 AM
wildcamaro's Avatar
I have the so called sewing machine noise after a heads and cam swap, but it def doesn't have that ticking noise that you got...I would pull the valve covers and at least make sure All the rockers are torqued properly...if not that either a bad lifter, wrong pushrods length, or it could be piston slap, but if piston didn't slap before it prob is in the. Valve train.
Old Jan 14, 2012 | 01:46 PM
Pull off the belt & start the car
Old Jan 14, 2012 | 03:52 PM
ws6outlaw's Avatar
Lightbulb
Is that safe to do? Run the car with no alternator or water pump or harmonic balance?
Old Jan 14, 2012 | 04:08 PM
technicalninja's Avatar
Yes, it's ok to run it for a bit belt free to isolate your noise.
I wouldn't drive it anywhere but a few moments will not hurt anything.
Old Jan 14, 2012 | 04:18 PM
sepsis's Avatar
The balancer doesn't need a belt to turn, it turns everything else.
Old Jan 14, 2012 | 05:58 PM
ws6outlaw's Avatar
That's right I'm a dumb lol
Old Jan 14, 2012 | 06:14 PM
Yesterday you showed us a vid with car running....have you pulled all that off since then without taking the time to just take off the belt & firing it up?
Old Jan 14, 2012 | 09:03 PM
ws6outlaw's Avatar
i didn't know until today that it was okay to pull the belt offand fire it up. Today i was busy doing other things. i'll probably do this tomorrow and see if the noise persists
Old Jan 14, 2012 | 10:11 PM
WHY! should I read the thread? I was the first to reply to your thread & gave you a heads up to my thoughts...
But hey, you've started to strip it...You've pulled of a few things...better take of the oil pump, it might be the squeak, it may need lubricating
Old Jan 14, 2012 | 11:25 PM
ws6outlaw's Avatar
ok my bad dude. i reread my post and that did kinda come off as a *****. really didn't mean for it to come off like that. i'll take off the belt tomorrow and see if the problem persists. that should tell me if the noise is really from inside the engine or not. i really am appreciative of the tips. i know we're all just trying to help each other out. im glad people are nice enough to post up ideas
Old Jan 15, 2012 | 01:46 AM
CS2 Sasuke XD's Avatar
same here, Mine sounds the same and my mechanic said the same^^^ was the issue
Old Jan 15, 2012 | 11:15 AM
ws6outlaw's Avatar
I took off the bigger belt and started the car. The noise was still there in a cold start up but just like before if I let it warm up it goes away. I left the smaller belt on tho.
Old Jan 15, 2012 | 11:18 AM
Bugger! yea small belt on's ok.
That noise sounded so much like mine did.
Old Jan 15, 2012 | 12:38 PM
ws6outlaw's Avatar
Yeah I was hoping. Now I might go ahead and make a weekend to tear off the valve coverage and make sure everything looks good
Lord please don't let it be a lifter. I don't think a collapsed lifter would stop ticking when warm tho
