Torquer 2, 241s, how much should I mill?
@ .050 intake duration, there is not alot of room for milling without cutting
valve reliefs into the stock flat-tops. I'm sure some people have done this
and can maybe get away .010-.015, but I doubt .020-.040" is possible.
Or, get a camshaft custom spec'd to your application that will have more PTV so you can have the compression you want.
