5.3 w/ built ls1 internals
Old Jan 16, 2012 | 07:31 PM
bbs350z's Avatar
Default 5.3 w/ built ls1 internals
hey guys i have a built ls1 that was setup for boost, and im looking to convert it all to an iron block for reliabilities sake and the fact that the starter mount broke off the aluminum block. i can get the 5.3 for about $100 and plan to bore it out to swap the ls1 stuff over. can i use all the roatating assebmly from my current ls1? ls1 is on stock bore. all the info would be greatly appreciated. and lastly what stroke would this make my motor? i was reading both cranks are identical in size
Old Jan 16, 2012 | 08:47 PM
supersick99z's Avatar
Stroke on the 5.3 and 5.7 is 3.622. The bore size is all that is different. Assuming you bore it to factory 5.7 size of 3.898 and use the stock crank with a stroke of 3.622 then you will just have an iron 5.7
Old Jan 16, 2012 | 09:30 PM
bbs350z's Avatar
^thats what i wanna hear! thanks! more info keep it comin please! because im using all of the internals form the ls1, would i need to rebalance anything at all?
Old Jan 16, 2012 | 11:38 PM
wildcamaro's Avatar
^^^yep you will have an iron ls1, just make sure to get your bore spot on so you have good piston to wall clearance
