Rod Bolts Reusable?
Old Jan 20, 2012 | 01:14 AM
gpr's Avatar
gpr
Default Rod Bolts Reusable?
I got a 2005 lq9, and since i have to pull the oil pan i wanted to inspect the bearings. Can i simply pull the rod caps off to inspect then reinstall them?
Wasn't sure if the stock rod bolts are reusable. I basically want to do this to check and make sure all bearings look good and one isn't spun or anything.
Old Jan 20, 2012 | 01:27 AM
ls1kbush's Avatar
If your going that far you should just buy new bearings (30 bucks for standard clevite) and get some katech rod bolts just so you know it will hold up.
To answer your question- You can re-use them but would be cheaper in the long run to replace them now if you plan on reving it or making good power.
Old Jan 20, 2012 | 03:31 AM
butler's Avatar
If the bearings are worn crank may need to be resurfaced.
Old Jan 20, 2012 | 08:55 AM
mark21742's Avatar
I agree with above posts, go ahead and pop new bearings in and upgrade your bolts....they are the bottom end weak point....I ran Katech with no problems st all and would recomend them in a heart beat
Old Jan 20, 2012 | 09:44 AM
gMAG's Avatar
There's a method to re-use the rod bolts.
I hesitate to do this because the method describes increasing the normal torque angle to compensate for the already stretched bolt.
Sounds like a hit or miss method to me.
For $35 extra, and the fact that you've come this far, I'd rather be sure that those bolts are stretched to the proper degree.
Old Jan 20, 2012 | 02:40 PM
3rdCoastPowerSports's Avatar
personally i would never dig that deep into any engine and not put in new bearings, rods and rod bolts. Mark21742 is correct the RODS, rod bolts and stock bearings are the weak link in the LS puzzle. R&R that stuff. if you want to go cheap (and still good quality) get some scat I beams (the come with ARP bolts) and i believe they make them for stock pistons if you call them up and Clevite bearings. since your there you mind as well get hone and put in new rings (make sure you check your bores with a dial bore gauge if you dont take it to a machine shop for the hone).
Old Jan 20, 2012 | 03:14 PM
gpr's Avatar
gpr
Well i'm not sure what is up with the engine yet as one cylinder is low on the leak down test. Never built a ls engine so i'm not sure what does and doesn't need replaced.
What about the crank mains? do they require new bolts everytime you take them off? Just trying to figure out what i all need, but i need to dig further into the engine first.
Old Jan 20, 2012 | 03:22 PM
ANTICOP RAM AIR's Avatar
Why the F would you do all that work and be a cheap *** where it really counts? Its possible to reuse them but so is performing brain surgery on yourself... just cause you can doesnt mean you should....
Old Jan 20, 2012 | 03:24 PM
mark21742's Avatar
If a cylindet comes in low during a leakdown test try squirting a little oil in that cylinder, then do the test again....if your pressure leaks down the same most likely its in need of a valve job. If pressure holds better your probably looking at rings.
Old Jan 20, 2012 | 03:26 PM
mark21742's Avatar
Yes you can reuse the mains, but I'd throw money at new better main bolts too....don't went your engine coming apart because of an old stock bolt that was reused. Look at it as insurance
Old Jan 20, 2012 | 03:35 PM
gMAG's Avatar
Crank mains...yes, new bolts.
Old Jan 21, 2012 | 10:50 PM
I8UR4RD's Avatar
i wouldnt even begin to check them, because since i have them out, id naturally know that knew ones were going in. while i had the chance. katech makes the most badass bolt around. do it to it. and throw those others in the trash.
Old Jan 22, 2012 | 12:52 AM
mark21742's Avatar
I do have a very big complaint about the Katech bolts though....they are too pretty to be hidden away deep inside the engine
Old Jan 22, 2012 | 12:56 AM
need2speed94's Avatar
I support the idea to just invest in some new rod bolts... might as well do it now before you go out and have fun and then come home with a thrown rod. Wish I woulda picked up some new rod bolts I suggest some ARP's.
Old Jan 22, 2012 | 01:15 AM
wildcamaro's Avatar
You do not need new main bolts...
Also my opinion on rod bolts is unless you are going to boost, juice, make 500+ , or spin past 6500rpm consistently (road racing) then yea get rod bolts...BUT...if you are only building a nice street machine I wouldn't invest 200 bucks on rod bolts unless you are going to have the power to break them..ls1s are known for their bottom ends! The rod bolts are the "weakest" part just bc everything else is so stout...I say run the stockers but get the bearings for sure!
Old Jan 22, 2012 | 01:19 AM
You sound pretty smart, but I say this guy should still invest in some rod bolts. I threw a rod in my 98 LS1 (heard those have weaker rod bolts), anyways... it was a bone stock motor. But as for what you said about boost, rod bolts are a MUST. If I threw a rod on a bone stock motor, anyone with a brain should upgrade rod bolts if they go the boost route. I've heard ARP 2000 bolts hold up well for boosted motors. +1 for your comment.
Old Jan 22, 2012 | 07:21 PM
chrisfrost's Avatar
The big question is why did You throw a rod ,,,,,,,,,,,,because the bearing spun or because a bolt let loose ,,,,,,,,,,,I'd be willing to bet the bearing was the reason or just plain rpm's and power and it broke somewhere between the little and big end .
Old Jan 22, 2012 | 07:30 PM
Never tore down the block... I assumed it was a weak rod bolt that finally crapped out. And it was a bone stock motor so it wasn't that it couldn't handle a surplus of power.
