Yella Terra Installation
I searched but couldn't find much on my issue.
I bought a set of Yella 6645 rockers New in the box from a fellow forum member. These were unopened.
So I just tried to mock things up on the bench. The stock bolts do not go through the rocker shafts on 2 pairs. The rest are fine.
There were no bolts in the kit.
What I did read when searching is that bolts do come in the kit.
Anyone seen this?
Seems to be a quality control problem from old Yella.
Ron
Nothing on the rockers.
The instructions that came with are universal.
I need an 8.0mm drill to fix the 2 problem units.
I sent Yella an email. Wonder if they will answer.
BTW, on the ones that the stock bolts fit fine on, thread engagement in the head is actually slightly better than stock. I have AFR heads so there is no bottom to the holes.
Ron
I really only need to open them uo .0015".
Now the question of bad parts and build dates has come up....not what I needed to hear.
Ron
Somewhere, I have my instructions. I'm headed out right now, but can scan the instructions later if you like.
I did send them an email.
The instructions with mine seemed generic. Not LS specific. So if yours are different, it would be interesting to see them. No rush, I'm just in the mock up stage.
Thanks!
ron
Thanks!
ron
I think we're talking about the same directions.
I'll post them anyway, tommorrow.
We have the same destructions. So no need to post.
I looked at your 67 Camaro post, very nice!
My Nova is Blue/White. My bro has a stunning 69 Camaro vert.
Neither is LS powered.......
Thanks again!
Ron
Although the process is somewhat different with stud mount rockers on a rat motor, I have done a lot of geometry setups so I know what to look for.
I just wish the issue of these things busting wouldn't have come up.
Neither the seller or I know when this set was made. So we will discuss with YT. Other than that, it's full steam ahead!
One question though, the AFR upgraded springs are going to be above 400lbs over the nose with my .640 lift cam. I have heard....haven't seen it in writing from YT, that these rockers don't like that. I dunno, that seems really odd.
Ron
Ron
No quality issue with the bolts. They all come with bolts. The factory bolts have a slightly larger shank on the neck and will be tight on fitment .
With all 6645s you get Pedestals, bolts, and shims in the kit
We have 8mm bolts at Meridian MS contact Doug Smith
Double check they haven't been a repack, also post up some pics of the rockers( or PM me ) so I can identify them
Jim
Anyone seen this?
Ron
Here are some pics. There was no top to the box. But the inside tray was sealed. I opened it.
Got ya on the bolts. There simply wasn't any in here.
Are you Jim from YT?
The fellow I bought these from is rather embarrased, he knew nothing of possible issues. We spoke on the phone, very nice guy. Whoever sold to him, probably removed the top of the box.
Thanks.
Ron
