Compression question
Old Jan 21, 2012 | 06:18 PM
poopman's Avatar
Default Compression question
I have a set of trick flow 215's, with 59 cc,i was wondering what pistons would be best recommended for lowering my compression enough that i could supercharge or turbo my car eventually. Forgot engine is a 346
Old Jan 22, 2012 | 07:02 PM
S10xGN's Avatar
A 15cc dish shows 9.52CR and a 22cc dish shows 8.87CR...
Old Jan 22, 2012 | 07:28 PM
poopman's Avatar
Thanks that means i can Keep my 59cc trickflow 215's to run boost
Old Jan 22, 2012 | 08:43 PM
mark21742's Avatar
Should actually work pretty good. By running a small chamber with a dished piston most of your combustion pressure will be on the center of the piston instead of out towards the ring lands.
Is look at the -15cc pistons to stay at or just over 9.0.....you might not be able to run as much boost in the end, but it will be more snappy at low/no boost in the lower rpms.
Old Jan 23, 2012 | 07:17 PM
S10xGN's Avatar
My GN powered S-10 has a 9.2 static CR and I can run 23# boost with alky injection. A lot will depend on setup, tuning, and timing...
