Anyone mind calculating my CR?
Old Mar 17, 2004 | 11:55 PM
Whistler's Avatar
Sawzall and Welder Mod
Default Anyone mind calculating my CR?
I have 6 litre heads with 73CC chambers, stock graphite gasket, and Diamond -8.6 cc dished pistons on a 3.9 bore...
8.something...
Old Mar 18, 2004 | 12:07 AM
angst911's Avatar
8.82558993883869 : 1
assuming the block isn't decked, if it has been, probably more likely to be
8.9984011129872 : 1
only unkown is your piston to deck clearance. using the following for everything else
3.9" Bore
3.622" Stroke
73 CC Chamber
.051" Gasket Thickness
3.9" Gasket bore
8.6cc dish
Old Mar 18, 2004 | 07:55 AM
Whistler's Avatar
Factoy deck... .007 out of the hole, .044 piston to head clearance would be 8.82:1?
Thanks!
Old Mar 18, 2004 | 09:34 AM
VSGLS1's Avatar
Got one for ya also...
Lunati LS1 382 3.898" Bore, -8cc Reverse Dome Piston, 4.000" Stroke, 6.125" Rod Length, 63CC Chambers, heads decked about .015", Stock head gasket and stock deck.
Old Mar 18, 2004 | 10:02 AM
PurEvl's Avatar
how about 3.905 bore -2cc reliefs, 72cc heads and a felpro gasket
Old Mar 18, 2004 | 11:02 AM
TeeKay's Avatar
Check this link out. You'll get all you need! CR is about halfway down. That shows Whistler's CR as 8.6:1.
http://www.ondoperformance.com/calculators.html
