valve questions
Old Jan 28, 2012 | 08:50 PM
97badass's Avatar
Default valve questions
Trying to get a rough estimate on ptv clearance I put a stock ls3 head on my block with no gasket. My ptv clearance is good... But my heads will be milled .030 with a .051 head gasket. I should be good there right? Also looking at the rocker arm contact on the valve stem tip, its on the inside shoulder, how do I get it centered on the valve stem?
Old Jan 28, 2012 | 09:30 PM
JS01's Avatar
Need full cam specs & piston info to make guesstimate.
Old Jan 28, 2012 | 09:39 PM
97badass's Avatar
Stock lq4 pistons tsp 229/236/112/.623/.617 cam. Ls7 lifters, ls3 heads milled .030
Old Jan 29, 2012 | 07:42 AM
97badass's Avatar
Anyone?
