countersunk cam door bolt size
Old Jan 30, 2012 | 10:10 PM
3rdCoastPowerSports's Avatar
Default countersunk cam door bolt size
does any one know the size pitch and length of the new countersunk cam door bolts?
Old Jan 30, 2012 | 11:56 PM
NemeSS's Avatar
Iirc, they are m8x1.25 and about .625 length. I got a set or 2. I will check tommorow.
They usr a torx to fasten em down
Old Jan 31, 2012 | 04:05 AM
vettenuts's Avatar
Torque value changes as well. I have the GM part number or you can contact SDPC who has all the information. There is also a non-countersunk version available aftermarket which would be my preference.
Old Jan 31, 2012 | 10:58 AM
thanks for that info. the dealer doesnt have any in stock and i need them today so im going down the street to my industrial supply place and im sure i can find some there.
Vettenuts i agree with you, i like the original flat faced bolts better. wonder why they went to countersinking the cam?
Old Jan 31, 2012 | 11:01 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
The VVT camshaft actuator needed the clearance.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jan 31, 2012 | 11:04 AM
ah i see. which motors did they put that on? i know the LS2 block is set up for the DOD but not used and doenst have the vvt
Old Jan 31, 2012 | 11:09 AM
L92. L76 (G8 GT). L99 (2010+ auto trans Camaros). Some 5.3s and a few others I don't know the codes for off the top of my head
__________________
