Lifter Tick After Oil Change???
The engine was cold and I only let it idle for a few minutes. After I heard it ticking I was so pissed I shut it off and went to bed. It goes away as soon as I give it some throttle but slowly comes back at idle.
Did I do something wrong? Should I not use this oil? I think it had a very slight tick before but now it is very noticeable. HELP!!
Previous owner might have filled it full of something thick to mask the tick. The Pennzoil is good oil so there's nothing wrong there.
Ok, I'll give that a shot. I let it drain for about 2 hrs so maybe that's the case....
Get some Marvel Mystery Oil and dump it in. It's the product with the highest success rate I've heard of for unsticking and quietening lifters.
Or you can just keep running it and see if it clears up on it's own. You have to pull the head to get to the lifter so that's your last resort.
After a few minutes the top end will surely get oil, unless there is a blocked passage. So it's most likely not that the top end isn't getting enough oil yet and should let it idle more.
I would also jump to the conclusion it is a lifter, stock lifters are very reliable. I would sooner suspect a rocker is shedding needle bearings. Or an exhaust leak.
Been there done that, but I would suspect if you had a bad rocker you would have some needle bearings in the oil. Run a magnet through the oil you drained to be sure.
Here is one post from a current thread.
https://ls1tech.com/forums/15911862-post39.html
Switching oil brands not weight netted a 50%(obviously subjective) noise reduction. That still was not good enough for that poster but is a good example of what I am saying.
Within and oil weight there is a RANGE some will be thicker or thinner, additive packages vary, how much oils shear down or thicken as they are used would play into it as well.
The fact this began immediately upon oilchange leads me to think the particular oil chosen is just louder. But beyond that IF there is a mechanical problem I would suspect a rocker before a lifter.
I think sometime back in the 70s lifters were a genuine problem and ever since ever tick has been blindly blamed on them despite them rarely being the cause. Exhaust leaks are the most common cause on gen 1 and gen 3 motors. Sofar it seems to me the gen 3 stuff seals that up a lot better.
The post about some oils being different is spot on. Royal Purple had an amazing write up on oil viscosity. It pretty much said (if i remember right) a 0-30 could be sold as a 5-30 and a 5-30 as a 10-30 etc. from their stand point its not worth it to do so because of the cost of making it. But for standards(SAE) it can be done.
