pcv ?'s
Old Mar 3, 2003 | 07:28 AM
last of the Z28's's Avatar
Default pcv ?'s
do the 2001-2002 have the same oil consumstion problems as the others? just curious? thanks guys!
Old Mar 3, 2003 | 03:26 PM
Dan's Avatar
Dan
Default Re: pcv ?'s
I have a 2001 formula and I burn around 1 qrt for every 2000 miles. I tried fuel filters in the PVC line but that didn't help. I think it caused a service engine soon code. My next step might be a catch can? or mixing 5w50 with 10w50 oils.
Old Mar 3, 2003 | 03:32 PM
JRcamaroZ28's Avatar
Default Re: pcv ?'s
Well if you have the LS6 intake you will probly have the LS6 valley cover which has the revised PCV setup compaired to the 98-00. I just replaced my valley cover when I changed over to the LS6 intake so i guess i'll see if it has any changes in oil useage. Before I was useing around 1 - 1.5 Qts. per 3000 miles.
JR
<small>[ March 03, 2003, 03:33 PM: Message edited by: JRcamaroZ28 ]</small>
Old Mar 3, 2003 | 05:37 PM
David Plum's Avatar
Default Re: pcv ?'s
Sorry i don't have the part # for a new pcv valve GM is installing ck with dealers but it's what looks like a pcv smaller hole in the end and no ck valve I posted it on the vette forum about a month ago.
