Heads and cam are going on this weekend
Old Mar 19, 2004 | 11:30 AM
95z6spd's Avatar
Default Heads and cam are going on this weekend
My dads 02 Camaro Z28 is going to Mikey at Rapid Motorsports tomorrow for a head and cam install. Car has run a best of 12.68@107.42 with only SLP LT's with cats, Slp lid, Phonix 3500 stall, 17" Torque thrust II's w/ nittos, Borla cat back , metco control arms, bmr panhard rod and hypertech PP
Parts being installed:
Patriot LS6/LQ9 59cc Stage II heads !!(WHICH HEAD GASKETS SHOULD BE USED TO OBTAIN 11.2:1 CR?)!!
Comp cams XE-R 226/.584/114 single pattern cam
Harland Sharp 1.7 roller rocker arms
Rollmaster double timing chain
85mm Z06 mass air sensor
Accufab 75mm throttle body
Asp underdrive pulley
Taylor 10.4 mm wires
Katech tensioner
Slp torque arm
Richmond 3.73 gears
Mikey's dyno tuning
since the last time at track we cut open the airbox and installed a Trans Go shift kit.
What does everyone think it will make on the Dyno and any estimates on 1/4 mile times and trap speeds with this combo. Car is a full weight every option car.
We are hoping for 400rwhp locked and 11.4's @120 on the drag radials
Let me know what you goes think
thanks
Old Mar 19, 2004 | 02:33 PM
RAN's Avatar
RAN
I think car will be awesome!!
Your Dad
Old Mar 19, 2004 | 02:41 PM
30th TA 0219's Avatar
Well, we expect another post Monday on HP results and next Saturday on track times
Old Mar 19, 2004 | 02:42 PM
XFACTOR's Avatar
Should be a beast!!Let us know how she turns out and what kind of power it makes!!!
Old Mar 19, 2004 | 04:05 PM
Jim Mills's Avatar
Should be awesome once it's done. It's like a whole new car I just install H/C and I'm loving it
Old Mar 21, 2004 | 10:48 AM
95z6spd's Avatar
We just dropped it off on saturday morning. Mikey was going to Atco and he has a trans to do on monday morning. Then he will start on the Z. We are excited. It should make some power , even through the A4.
Old Mar 25, 2004 | 02:28 PM
95z6spd's Avatar
The results are in 403rwhp and 378rwtq w/ tge converter locked. What do you guys think. The torqur #'s are not locked just the HP #'s. The air/fuel ratio is around 12.8:1 across with 28 degrees of timg.
Old Mar 25, 2004 | 02:32 PM
94form2000z's Avatar
My first thought is I'd of used GM gears instead of Richmond. Whiney a$$ things. Good numbers for that size cam.
Old Mar 25, 2004 | 02:47 PM
95z6spd's Avatar
I'msorry they are Precision gears but they still are whiny
Old Mar 25, 2004 | 03:01 PM
GM Motives.. or the originals are the best to use.
Old Mar 25, 2004 | 03:25 PM
boomcase's Avatar
Congrats on the power #s , get it to the track and let us no what it does.
