Help ls6 intake!!!
Old Feb 11, 2012 | 06:19 PM
jerrito98ss's Avatar
Default Help ls6 intake!!!
How can you tell if a ls1 ofom an ls6 intake
Old Feb 11, 2012 | 06:25 PM
TransAmWS.6's Avatar
LS1 intake should have an EGR plug behind the TB, you could also just take a look at the part number.
Old Feb 11, 2012 | 06:28 PM
Oh ok cause im buyin an ss and the guy said it had ls6 pistons and intake oh and it is a ls6 intake what cam would be good for it?
Old Feb 11, 2012 | 06:34 PM
What cam would be good for it? There are tons out there to choose from, so it all depends on what your goals are for the car man.
Old Feb 11, 2012 | 06:37 PM
Is the tube on the intake itself or throttle body? And i want to make it my daily driver
Old Feb 11, 2012 | 06:57 PM
The tube should be literally directly behind the TB, it's just a black hose sitting there, not too hard to miss.
Depends on how radical of a cam that you can tolerate for a daily driver, honestly, just take a few minutes and run a good search on here. There are TONS of threads that have good information regarding the different types of cams that you can get into.
Old Feb 11, 2012 | 07:29 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Welcome to LS1tech!
A search resulted in: https://ls1tech.com/forums/generatio...-manifold.html
Old Feb 11, 2012 | 07:36 PM
Ok its an ls6 for sure and thanks for the help guys
Old Feb 11, 2012 | 07:53 PM
garygnu's Avatar
look at a TSP 224r cam pkg ,or consider a thunder racing tr224 cam pkg.I don't believe there a diff between a ls1 piston and a ls6 piston.
Old Feb 11, 2012 | 07:57 PM
BOBS99SS's Avatar
Captain Double Post
why are there ls6 pistons in there, what year is it?
Old Feb 11, 2012 | 10:32 PM
wildcamaro's Avatar
I doubt someone went through the trouble of replacing Ls1 pistons with ls6 ones (although the ls6 pistons are made of better quality) it might have an ls6 block, but it still wouldn't have had ls6 pistons...it is not impossible that he swapped them but like I said...quite unlikely...ls6 intake is the way to go for sure though...it dominates the ls1 by far I could tell the difference when I swapped
Old Feb 11, 2012 | 11:19 PM
Its an 02ss camaro m6 full exhaust longtubes ls6 intake slp lid ls6 oil pump and thays as much as ive confirmed so far
Old Feb 12, 2012 | 12:20 PM
LS1121's Avatar
I remember when my buddy bought a Lincoln, it had Mustang Cobra emblems on the fenders and under the hood. The salesman told him it was a "Special Edition" lincoln. lol
Don't believe what people tell you so much as checking for yourself, even more so when they are trying to sell you something. Someone taking an LS1 apart to install LS6 pistons????? highly unlikely but possible. More so it would be an LS6.
