error help
Old Feb 13, 2012 | 09:00 AM
leon phelps's Avatar
Default error help
Hello,
Doing an ls1 swap into a 65 impala. engine was running fine. I removed the computer to do some welding (seat brackets) and now have put the computer back in and car will not start.
I have 58 psi at the rail.
I get three error codes now. Had none before. first one is n/a, second is p107 and third p118. I had checked for error codes a couple days ago and had none.
I am confused. Any help appreciated.
Old Feb 13, 2012 | 10:08 AM
disconnected the intake air sensor and the engine started right up. off to autozone to replace it then to try the next code.
Old Feb 13, 2012 | 11:12 AM
wildcamaro's Avatar
Are you sure you got a good ground for PCM?
Old Feb 13, 2012 | 11:14 AM
wildcamaro's Avatar
My bad I didnt read second post lol
Old Feb 13, 2012 | 11:26 AM
weird thing...replaced sensor, now it runs but I cant get rid of the code. guess Ill unplug the battery over night and see if it goes away.
