what rocker arms to run??????
No, you're wrong. Apparently the roller tip is just a gimmick and it doesn't roll at all and it's just too heavy to be on top of the valve because the few grams that it weighs will bounce around and push open the 600+lbs of seat pressure of the spring and cause valve float.
That's what I hear anyways....
But what would I know, I'm just some guy on LS1Tech............
Rate of the spring and coil bind all play into it not just pressure.
I have never had valve train issues I don't ? What my guy says and it works.
I know people that can screw up a cold glass of water though.
Tim
